2000 silverado driver side window failure
2000 CHEVROLET SILVERADO
CARTER
having a problem w/ either the window switch or the window motor. when the switch is pressed to raise/lower there is a clicking noise from a relay but no window movement. I suspect a fuse might be the problem but which one?
thanks, Carter
Jan 12, 2006 at 3:15 AM
2CARPRO JACK
  • 11,533 POSTS
there are no fuses for each window. Might be a bad window lift motor
Jan 12, 2006 at 9:52 AM
LIGHTHOUSES
You can check the motor by hooking a power source to the plug of the switch pos. to one of the connectors and neg to the other. try both ways 1s up and 1s down. you can use a battery charger for this with wire so you can get to the conn. we do it at work all the time. 8)
Jan 12, 2006 at 12:39 PM
