1998 Chevrolet K1500 No Start Fuel Pump
VAUGHN
I have a 98' chevy K1500 Vortech 5.7 liter, which has 160,000 miles. I drove to work about 15 miles came home went to the store, about 12 miles and when I got tried to start it later in the day, it wouldn't start. The fuel pump is not pumping when I turn on the key. The fuel pump is less than a year old. And I tried changing the fuel pump relay and still nothing... I have checked all other fuses. Is there a reset button for the fuel pump or an inline fues? What else can it be. Your help will be very appreciated
Aug 15, 2007 at 9:06 PM
MERLIN2021
  • 17,250 POSTS
Try a test light and check for power at the pump. If none and fuses and relays are ok, check wiring, could have a bare spot someplace. It happened to me! No warning just wham, no start!
Aug 16, 2007 at 12:02 AM
Suggested Repair
Use a test light to check for power at the fuel pump. If there is no power and the fuses and relay are good, inspect the wiring for a bare or damaged spot.
Conversation Summary
A 1998 Chevrolet K1500 with a 5.7L Vortec would not start, and the relatively new fuel pump did not run when the key was turned on. The owner had already replaced the fuel pump relay and checked the fuses. The expert advised checking for power at the pump and, if none is present, inspecting the wiring for a bare spot.
