1997 Chevy K1500 won't start, fuel problems
SHANE34
  • 1997 CHEVROLET TRUCK
1997 K1500 4X4 350 with 160,000 miles will not start, I have fuel pressure at the schrader valve, but no fuel is getting through the throttle body
Wednesday, August 15th, 2007 AT 1:20 AM
Fuel is at the rail however if its not the correct pressure it not gonna work.
In this case as stated not going thru the TBI-I would say the PCM is not pulsing/energizing the injectors.
No fuel to combust-
Recommend you check for spark before you continue with the fuel problem
The computer works this way: when it sees something it has to make something happen.
Wednesday, August 15th, 2007 AT 1:44 AM
