1997 Chevy Truck no start no spark
VINSONGUY
  • 1997 CHEVROLET TRUCK
  • 6 CYL
  • 200,000 MILES
My truck will not start, I parked it for a period of time approx. 2 mos and now it wont start, I have good fuel pressure and have replaced the cap rotor and pick up module the coil tests good but spark tests show no spark I put a scan tool on it and the crank sensor is working
What next
Wednesday, November 18th, 2009 AT 8:40 PM
Do you have power to the coil, also did check the ICM
Wednesday, November 18th, 2009 AT 8:42 PM
VINSONGUY
I swapped the working icm and coil out of my suburban to eliminate them as the problem and still had no spark
Wednesday, November 18th, 2009 AT 8:47 PM
CPS good sounds like PCM or its not getting an ignition reference signal.
Wednesday, November 18th, 2009 AT 8:54 PM
