I have 1991 Chevy Cheyenne 3/4 ton with a 350ci enigine. The truck has 152000 miles on it. The other day my wife was driving to work and it acted like she didn't give it enough gas, died, and wouldn't start back up. I went into the hood and saw that there was fuel coming out of the injectors and spark coming from the coil when the truck was turned over. I have recently replaced the plugs ,cap and rotor. Today I replaced the ignition module that is located on the distributor and it still didn't start. Money is starting to get tight and I need to find the problem. I just don't know where to go from here. I thought about the wires, but I wouldn't think it would just not even try to start if one or two were bad and the rotor is just a metal strip so not really an issue there. What do you think?
May 26, 2007 at 8:29 AM
