windsheild wiper problem
BILL8
I have a 1998 Cheyenne with a little over 150,000 miles and a vortex v-6. After the last ice storm we had my wipers only work on high. The intermittent and low speeds do not work anymore. Any information you could give me will be greatly appreciated.
Mar 10, 2007 at 1:39 AM
CHEVY22
  • 1,375 POSTS
this could be several things , first if you have some tools and are willing to dive in , the wiper motor is under the hood and the cover has three bolts in it , pull the cover off and you will see a printed circuit board , check it closely for and burned spots and let me knwo
Mar 10, 2007 at 1:53 AM
BILL8
Thanks, I pulled the cover off and it appear that there was a connection that had a small round piece of plastic covering it that has been bent and the plastic covering has been broke.
Mar 10, 2007 at 3:09 AM
CHEVY22
  • 1,375 POSTS
thought might be it , you can but the printed circuit, board alone without the motor
good luck
Mar 10, 2007 at 3:23 AM
BILL8
I pulled the circuit board out and found a replacement wiper pulse board online that looks just like it. Could I replace just this board?
Mar 10, 2007 at 4:02 AM
CHEVY22
  • 1,375 POSTS
yup , no need for the rest of it , there was a recall a while back and we were doing like 50-60 per day , it should take care of your problem, but i would try to get dealer parts , much more reliable and if it fails you can return it easily
Mar 10, 2007 at 4:04 AM
BILL8
Thanks, I will pickup the replacement wiper pulse board an replace it. You have been a great help. Thank you.
Mar 10, 2007 at 4:23 AM
CHEVY22
  • 1,375 POSTS
no problem
Mar 10, 2007 at 4:46 AM
CHEVY19981500
[quote:0507773ae0="CHEVYII"]no problem[/quote:0507773ae0]
i need some help pls
May 25, 2007 at 4:20 AM
