1996 Chevy 2500 Converter Lockup
CHRIS CORREIA
Hi, I have a 1996 Chevy 2500 4wd 120000 miles 4L80e trans. My torque converter keeps coming in and out of lockup while driving in any gear and any speed. here's what i've done:
replaced the brake light switch
Trans. professionally rebuilt
checked fluid.
The snap-on code reader showed the brake switch was constantly going on and off so I replaced it (no results) This problem was present BEFORE the trans build. The problem was intermittent (maybe once a month during a 15 min drive, to all the time now. No codes have come up. The problem occurs whether the truck is cold or hot, but seems more noticeable when cold. The trans. shifts perfectly.
May 16, 2007 at 12:55 PM
E40WATER12
  • 522 POSTS
I thinking youre TCS
https://images.2carpros.com/forum/automotive_pictures/75270_TCS_1.jpg
switch is not good, That would cause those issues you are having.
May 22, 2007 at 6:47 PM
Suggested Repair
Inspect and replace the TCS switch, which the expert believes is causing the torque converter to cycle in and out of lockup.
Conversation Summary
The owner of a 1996 Chevy 2500 with a 4L80E reports the torque converter repeatedly locking and unlocking at any speed or gear. The brake switch was replaced, the transmission was rebuilt, and the fluid was checked, but there are no codes and the transmission shifts normally. The expert suspects a faulty TCS switch.
