1995 Chevy Truck Brake light switch
1995 CHEVROLET TRUCK
13,100 MILES • V8 • 2WD • AUTOMATIC
JBARRY4U
The truck will not come out of park when running and the brake lights do not work. Is it the brake switch? If so where is it located. It starts and runs fine in nuetral.
Mar 2, 2009 at 7:45 AM
Follow the brake pedal arm till it comes up to the brake support bracket its here. If brake fuse is okay-look for power the switch connector one of them should have it-now jumper the connector and see what happens. If power and brake switch okay-Get the shift interlock system checked out-
Mar 2, 2009 at 7:54 AM
