BRAKE LIGHTS
LHALLJR
  • CHEVROLET TRUCK
MY BRAKE LIGHTS WILL NOT WORK. ALL OF MY OTHER LIGHTS WORK, PARK, SIGNAL, BACK-UP, BUT THE BRAKE LIGHTS AND THE CARGO LIGHTS DO NOT. I HAVE CHANGED ALL OF THE BULBS, CHANGED AND TESTED THE FUSES AND I HAVE CHANGED THE BRAKE SIGNAL SWITCH. WHAT DO I NEED TO CHECK NEXT? IS THE PROBLEM APPEAR TO BE IN THE BULB RECEPTICALS OR THE WIRING? WHERE DO I CHECK FOR THE GROUNDING WIRE AT ON THIS VEHICLE? ANY INFORMATION WILL BE GREATLY APPRECIATED.
Tuesday, July 17th, 2007 AT 6:01 AM
Heads up, what is this a 2009 model or what-you need to comeback with more data. Before I search the EWD to pinpoint your problem.
Reading it could be the cruise control messing around with it or the computer.
Thursday, July 19th, 2007 AT 1:43 AM
FRUSTRATION
I am having the same problem. I have replaced the switch behind the pedal, the fuse, and the lights themselves. Still no brake lights. All other lights working fine. Mine is a 1994 Chevy Silverado 1500.
Sunday, January 23rd, 2011 AT 6:14 PM
