1997 Chevy Truck BRAKE LIGHT SWITCH
1997 CHEVROLET TRUCK
172,000 MILES • 6 CYL • 2WD • AUTOMATIC
BWEBB
I've have to replace the brake light switch (4) times over the last 6 years and now it's bad again. Twice it was the contact that allows you to pull it out of park that went bad. This time it's the brake light circuit contact that's failing. Is this an issue with this switch or do I have a problem elsewhere. I may be just the lucky guy that gets the defective switches. Has anyone else had this problem?
May 13, 2010 at 1:26 AM
Could be the turn and hazard switch that's acting up the brake circuit goes thru there.
May 13, 2010 at 3:56 AM
BWEBB
[quote:6b3fd061a5="rasmataz"]Could be the turn and hazard switch that's acting up the brake circuit goes thru there.[/quote:6b3fd061a5]
I installed the new switch tonight and the brake lights are working fine again. I'll see how long this switch lasts.
May 13, 2010 at 1:20 PM
BWEBB
I installed the new switch tonight and the brake lights are working fine again. I'll see how long this one lasts.
May 13, 2010 at 1:23 PM
