98 k1500 Turn Signals
SCHOFFDOGG
  • 6 POSTS
I have a 98 Chevy K1500. My turn siganls recently went out. All my bulbs work and my hazards still work. I recently replaced my flasher and the signals worked for about an hour. I've checked all my fuses and the flasher and they are all good. Please tell me it's not my turn signal switch!
Jan 20, 2006 at 6:18 AM
SC1 RACING
  • 117 POSTS
if the right or left light indicator does not come on it will be a fuse or the signal switch
Jan 20, 2006 at 6:37 AM
SCHOFFDOGG
  • 6 POSTS
Is there another fuse besides the one in the fuse panel and the flasher?
Jan 20, 2006 at 6:44 AM
SC1 RACING
  • 117 POSTS
there are more fuses under the hood but i dont recall one for the turn signals. it is not a hard job to replace a signal stat its pretty easy, and less than 30 min of work. remove the plastic steering cover and check for power without signal on then turn left and right to see if any other wires power up.
Jan 20, 2006 at 6:49 AM
