1983 Chevrolet Celebrity Turn Signals
VALKIREMOON
my car is a chevy celebrity the year is 1983 and mileage is 2191485. I can't get the signal lights to work and I think that the flasher needs to be put in. Because i can't find one under the drivers dashboard where else would it go.
Mar 6, 2006 at 10:17 AM
PEPPERMRJ
  • 1,158 POSTS
Turn Signal: Under Instrument Panel On Column Support
Hazard Warning: In Convenience Center On Right Hand Side
Of Glove Compartment
The hazard flasher is located in the convenience center, under the dash, on the left side kick panel. The turn signal flasher is installed in a clamp attached to the base of the steering column support inside the car. In all cases, replacement is made by unplugging the old unit and plugging in a new one.
Good luck and let us know.
Mar 6, 2006 at 11:56 PM
Suggested Repair
The turn signal flasher is in a clamp at the base of the steering column support under the instrument panel. The hazard flasher is in the convenience center (described as the right side of the glove compartment and also the left kick panel under the dash). Replace a flasher by unplugging the old unit and plugging in a new one.
Conversation Summary
The owner of a 1983 Chevrolet Celebrity cannot get the signal lights to work and cannot find a flasher under the driver dashboard. The expert says the turn signal flasher is under the instrument panel on the steering column support, and the hazard flasher is in the convenience center. Replacement is done by unplugging the old unit and plugging in a new one.
