1989 Corsica Turn Signal Flasher Location
1989 GMC
JO32664
Where is the flasher located on a 1989 Corsica?
Feb 26, 2006 at 2:36 PM
JPAM
  • 307 POSTS
Flasher Relay?? check ur fuse blocks.. under hood and or inside panel(fuse panel) For the relay itself look for a square silver box about size of silver dollar.. Any other ?? just write back.. Thank u for stopping by at 2CarPros.. & check the link below for the cheapest parts around.. thnks Jess S.
Feb 26, 2006 at 4:24 PM
JPAM
  • 307 POSTS
jo32664 writes back in PM>> Thanks for your help. I did find it. You have to take out the little storage area that is on the left side. It has 4 screws and comes right out.<<
jpam.. jo32664 also informed me that it was a [b:27577a20e3]round flasher[/b:27577a20e3].. thanks 4 the info jo32664..
jess s.
Feb 28, 2006 at 2:53 AM
Suggested Repair
Remove the small storage compartment on the left side, held by four screws, to access the round turn-signal flasher. Also check the fuse blocks under the hood and inside the cabin if the signals still do not work.
Conversation Summary
The owner of a 1989 Corsica asked where the turn-signal flasher is located. An expert suggested checking the under-hood and interior fuse blocks and looking for a small square silver relay. The owner later reported finding a round flasher behind the left-side storage compartment, which comes out after removing four screws.
