Crankshaft/camshaft correlation on that code, the ditibutor may be off when you replaced it, simple check, spin engine to tdc and pull the dist cap and see where you set it, if that checks out of check the connector to the cam position sensor, this should be an easy fox, the cam and the crank signal are not getting the right info or I should say the cam pos sensor is giving the crank shaft sensor the wrong info check it out and let us know
thanks
jim
oh and leave some feedback if you were happy with your help, we all donate our time here helping others free of charge
SPONSORED LINKS
Sunday, February 25th, 2007 AT 11:28 AM
