Has it had any other problems? My family had a 98 tahoe that did the same thing, and after a bunch of tests and mechanics scratching their heads it turned out to be an ignition wire in the column. Ive heard of blazers having a similar issue. The tahoe would only do it every once in a while, but it scared the poop out of you when it did it. I dont know how to test it to see if thats the problem or not. Just sharing a lttle bit of experience with you, and maybe itll give you a place to start.
SPONSORED LINKS
Saturday, November 18th, 2006 AT 2:02 AM
