1997 Chevy Truck Stalled out and now it won't start!
KPRUITT
  • 1997 CHEVROLET TRUCK
  • V8
  • 4WD
  • MANUAL
  • 224,000 MILES
I was driving this truck and noticed a slit hesitation every once in a while, then one day on my way home from work it stalled out. I tried popping the clutch and still nothing. I came to a stop and tried turning the key over. It was trying to start but seemed like it was out of gas. I noiticed that I could not hear the fuel pump. I was told that it could be a cracked Distributor. Where should I begin?
Friday, June 11th, 2010 AT 1:50 PM
INTERNETMECHANIC
  • 700 POSTS
Start with the basics. If it cranks good but won't start, have a helper crank it while you visually check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure. Some of the national brand auto stores used to loan out a fuel pressure gage, if you don't have one.
To check for spark, pull a spark plug wire. Use a known good plug or spark tester in the boot. Ground metal part of plug/tester to metal part of engine, engine cranking, watch for spark.
Friday, June 11th, 2010 AT 2:50 PM
