Shuts off while driving?
1997 CHEVROLET TRUCK
150,000 MILES • V8 • 4WD • AUTOMATIC
ZACS
My 1997 Chevy 1500 keeps dying on me after I have been driving it for a while. If I drive it for an hour, it seems the engine gets hot and dies. then won't start unless I let it sit for 20min or so. was told this could be vapor lock? I recently replaced the fuel filter and fuel pump, so I hope that is not the problem.. my temperature gauge says the engine is not hot when it shuts off. not sure what the problem is here.
Jul 12, 2010 at 1:19 PM
  • CERTIFIED EXPERT
Next time it shuts off don't wait do below immediately to determine if its a fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Jul 12, 2010 at 2:57 PM
NINA MCKELVEY
I'm having the same exact problem with my 97 chevy k1500, is there any way you could tell me if you were able to fix the problem and if so, what was it? please and thank you.
Jan 11, 2023 at 5:21 PM
  • CERTIFIED EXPERT
  • 53,884 POSTS
This can be a defective fuel pump, when the engine stalls out turn the key off and then on again to see if you hear the pump running in the fuel tank for about 5 seconds. If so, let's check for spark in case the ignition coil is getting hot and failing.
https://youtu.be/baq_aEWNQ0Y
This guide can help as well:
https://www.2carpros.com/articles/engine-stalls
Please go over these guides and report back.
Jan 12, 2023 at 5:57 PM
