1989 Chevy Cavalier Window Switch Wiring Fix
2 doors or 4?
Convertible or not?
Pin F: Pnk (Power)
Pin E: Blu/Wht (RH Front Up)
Pin D: Tan (RH Front Down)
Pin C: Dk Blu (LH Front Up)
Pin B: Brn (LH Front Down)
Pin A: Blk (Ground)
Hope this works and you get it set up correctly. You can always test the circuits with jumpers. But remember when you are driving the motor you must jump Pin A to the opposite wire for the window you are driving.
Example: You want to drive the left front window down. Jumper pin A to pin E to supply the ground return path for the motor, and then jumper pin F to pin D to supply power to run the motor.
First, you need to find the ground and power terminals. I suggest drawing an image to keep your self straight.
With an ohm meter, check the pins on the switch for continuity. With all of the switches not pressed, the power terminal will not have continuity with any other pin. Mark this terminal F, and it should connect to the pink wire.
Now, press the RH Front Up switch and hold. Check from pin F to the other terminal that now has continuity. This is Pin E, and should connect to the Blu/Wht wire.
Press the RH Front Dn switch and hold. Check from pin F to the terminal that now has continuity and this is pin D. It should connect to the Tan wire.
Press the LH Up switch and hold. Check from the pin F to the terminal that now has continuity and this should be pin C. Connect the Dk Blu wire to this one.
Press the LH Dn switch and hold. Check from pin F to the terminal that now has continuity and this should be pin B/ Connect the Brn wire to that.
The ground is the terminal that has continuity with pin E, pin D, Pin C, and pin B with no switches pressed.
Hope this works for you.
Suggested Repair
Identify the unmarked driver-side power window switch pins with an ohmmeter before connecting the wires. With no switches pressed, the power pin has no continuity to other pins and should get the pink wire. Press each up or down switch and find the pin that then has continuity to power: right-front up is blue/white, right-front down is tan, left-front up is dark blue, and left-front down is brown. The ground pin has continuity to the four motor pins with no switches pressed and gets the black wire. Circuits can also be checked with jumpers, using ground and power on the opposite pins for the window direction being tested.
Conversation Summary
The owner of a 1989 Chevrolet Cavalier two-door without a console needed the driver-side power window switch wire layout. The pins were unmarked, although the ground was known. The expert listed pin functions and wire colors, then explained how to identify each pin by checking continuity with an ohmmeter while pressing the individual window switches.
