Chevrolet Cavalier Window Crank Removal Fix
SOOZQ
I need to bang out a dent in my rear door and I don't want to damage the door frame when I remove it. How do I remove the window crank without damaging it. The door frame is loose, but I need to remove the crank to take it off.
Feb 9, 2006 at 1:51 AM
PEPPERMRJ
  • 1,158 POSTS
If you are speaking of the actual window crank (device used to roll down window with your hand) it is held on with a circlip. Just push in the door panel and hook it with a sturdy bent up paperclip.
Good luck with your repair.
Feb 10, 2006 at 4:37 AM
Suggested Repair
The manual window crank is held by a circlip. Push the door panel inward and hook the circlip with a sturdy bent paperclip to release the crank without damaging it.
Conversation Summary
The owner of a Chevrolet Cavalier (year unknown) wants to remove the rear door window crank to work on a dent without damaging the loose door frame. The expert explains that the hand crank is retained by a circlip, which can be released by pushing in the door panel and hooking the clip with a sturdy bent paperclip.
