front wheels set back
200,000 MILES • 4.0L • 4 CYL • FWD • AUTOMATIC
RAMBO1980
  • 5 POSTS
I have one front tire centered on the drivers side but the passengers side is pushed back and it rubbs on the back when o turn it rubbs even more I think it was hit when they sold it to me how do I fix it if I put a new arm will it help the tire go to its original spot I could not get it aligned cause of it they told me I have to center the tire is there a way to fix it without taking it to the frame shop
Mar 28, 2016 at 7:50 AM
HMAC300
  • 48,601 POSTS
have it checked for a bent sub frame first before putting any parts on. Or take it back to where you got it, they should fix it or take them to court.
Mar 28, 2016 at 8:11 AM
RAMBO1980
  • 5 POSTS
Yeah it's what I thought it must be something bent I would show u the pic how the tire is but it don't let me download it
Mar 28, 2016 at 8:22 AM
HMAC300
  • 48,601 POSTS
that's ok I've seen them plenty of times......
Mar 28, 2016 at 9:28 AM
RAMBO1980
  • 5 POSTS
Is there a way I can fix it maybe tie it to a tree and try to pull the tire to the front on reverse
Mar 28, 2016 at 10:05 AM
RAMBO1980
  • 5 POSTS
The reason I'm saying that it's because I don't have the money to take it to a frame shop they very expensive here in Louisiana and I was wondering if there might b a way to fix it myself I can return it but I bought it from a friend and not a dealership and I found this site with great experts seeking for an advice or if they knew a way to push that tire just a little forward so the alignment computer can get a good reading it eats the tires way faster and can't take it to work cause in 4 days it eats the inside of those fronttires
Mar 28, 2016 at 10:16 AM
HMAC300
  • 48,601 POSTS
when a frame is bent it has to be replaced or straightened there is no shortcut or cheaper way to fix this.
Mar 28, 2016 at 10:39 AM
RAMBO1980
  • 5 POSTS
Ok thank u so much
Mar 28, 2016 at 10:57 AM
