1994 Chevy Cavalier HYDROLIC FLUID FOR CONVERTIBLE TOP
1994 CHEVROLET CAVALIER
37,000 MILES • 6 CYL • 2WD • AUTOMATIC
AMBER91601
I NEED TO PUT MORE HYDROLIC FLUID IN BUT DO NOT KNOW HOW. I SEE THAT IT IS LOW AND THERE ARE BREAKS IN THE LINE. THE TOP IS DOWN AND WILL NOT GO UP.
THANKS
Jul 2, 2010 at 4:44 AM
HMAC300
  • 48,601 POSTS
there should be a removable panel by the pump& motor. When ever you work on the top it should be in the up position. so yours will be fun to get to. YOu should find the leak though as it will get all over otherwise. You use either DextronIIE or DextronIIIATF for the fluid....
Jul 3, 2010 at 6:37 AM
