2004 Chevrolet Cavalier Wiper Arm Falls Off
CSHELDONSMOM
my windshield wiper arm stop working on the passenger side removed the cover and pushed it back on the ball but still comes off does it need a clip or somthing
Apr 14, 2007 at 12:03 AM
  • 75,988 POSTS
[quote:791ff60986="csheldonsmom"]my windshield wiper arm stop working on the passenger side removed the cover and pushed it back on the ball but still comes off does it need a clip or somthing[/quote:791ff60986]
Check the other side should tell you what's securing it normally its a nut maybe it crossthreaded
Apr 14, 2007 at 12:28 AM
CSHELDONSMOM
[quote:df92ce04fa="rasmataz"][quote:df92ce04fa="csheldonsmom"]my windshield wiper arm stop working on the passenger side removed the cover and pushed it back on the ball but still comes off does it need a clip or somthing[/quote:df92ce04fa]
Check the other side should tell you what's securing it normally its a nut maybe it crossthreaded[/quote:df92ce04fa]
have another look and it is sitting on a white ball i think i i will probably have to replace the whole arm
Apr 14, 2007 at 4:07 AM
Suggested Repair
Compare the passenger wiper arm with the driver side to see how it is retained. These arms are normally secured by a nut, so check whether that nut is missing or cross-threaded before replacing the arm.
Conversation Summary
The owner of a 2004 Chevrolet Cavalier said the passenger windshield wiper arm keeps coming off the white ball after the cover was removed and the arm pushed back on, and asked whether a clip was needed. The expert advised comparing it with the other side, noting that a nut normally secures the arm and that the nut may be cross-threaded. The owner then thought the whole arm might need replacement.
