1989 Chevy Cavalier Rocker Arm Torque Fix
CHEVROLET
DENNISWEAVER
I have a 1989 Chevy Cavalier Z24. It currently has 189325 miles on it. We have replaced the Rocker arms on it because they were slightly bent. Does anyone know what the torque is for the nuts that hold them? We have taken the engine apart seveal time trying to adjust this correctly and have not had any luck. Any help would be appreciated.
Dec 30, 2006 at 9:07 AM
NIGHTSHIFTED
  • 12 POSTS
If your not a subcriber to the manuals linked to this site you can go to www.autozone.com and get the specs and the proceedure for tightening your rockers. When you first go to the page go to the upper left corner and click on "change current vehicle". Click in all your information. Once you have that vehicle listed in the corner you can go to repair info I think it was. Then just look up what you need.When you get there make sure your looking at the right engine. It gives info for several so you might have to scroll for your particular proceedure.
Jan 1, 2007 at 2:51 AM
MIKEYBDMAN
  • 623 POSTS
[quote:a0260f621e="dennisweaver"]I have a 1989 Chevy Cavalier Z24. It currently has 189325 miles on it. We have replaced the Rocker arms on it because they were slightly bent. Does anyone know what the torque is for the nuts that hold them? We have taken the engine apart seveal time trying to adjust this correctly and have not had any luck. Any help would be appreciated.[/quote:a0260f621e]
For the 2.0L engine: Rocker Arm Stud 33-40 ft.lb
Rocker Nut 11-18 ft.lb
For the 2.8L engine: WITH NON-ADJUSTABLE ROCKER STUDS
Torque rocker arm nut to 24 Nm (18 lb. ft.).
Jan 1, 2007 at 11:17 AM
Suggested Repair
Confirm whether the engine is a 2.0L or 2.8L, then torque the rocker nuts to the matching spec: 11-18 ft-lb for the 2.0L (rocker studs 33-40 ft-lb), or 18 ft-lb (24 Nm) for a 2.8L with non-adjustable rocker studs. Follow the correct tightening procedure for that engine.
Conversation Summary
The owner of a 1989 Chevy Cavalier Z24 with 189,325 miles replaced slightly bent rocker arms and asked for the rocker-nut torque after several unsuccessful adjustments. One reply directed them to Autozone repair information for the correct engine. An expert listed 11-18 ft-lb for 2.0L rocker nuts and 33-40 ft-lb for the studs, and 18 ft-lb for 2.8L engines with non-adjustable rocker studs.
