2003 Chevrolet Tahoe Fuel Efficiency Codes
TAHOE24FAN
I have a 2003 Tahoe with a 5.3 with 80,000 on it and we just drove up the Alaska Highway and when we got to AK the "check engine" light came on. So I had it scanned and the code came back as "fuel difficency" on banks 1&2. I cleaned the mass air flow sensor but it is still missing at idle. Once I accelerate it runs fine! Any ideas? Thanks!
Mar 28, 2007 at 2:19 PM
KIN CHAN
  • 453 POSTS
GIVE ME ALL THE CODES !!!
OBD2 & FACTORY ENCHANCE!!!!!!!!
NO CODE NO DEAL!!!!!!
Mar 29, 2007 at 12:24 AM
TAHOE24FAN
What do you mean? The code was fuel diffiency bank 1 and fuel diffiency bank 2. Is there a numeric code that your looking for?
Mar 29, 2007 at 3:22 PM
SERVICE WRITER
  • 9,123 POSTS
That is exactly what Kin means.
The 5.3 motors did have a problem with a leaking fuel pressure regulator, very fine, but there none the less. You can visually check that.
Mar 29, 2007 at 8:08 PM
KIN CHAN
  • 453 POSTS
every manufacturer maybe every model has their different criteria set and build into the softwareon how to monitor and whatever it takes to trip the code for the same code which is protcol as OBD2 by EPA ..it is call strategy..ie ford on most model use DPFE to monitor the EGR sytem and set P0402 ...some chevy use MAP sensors to detect P0402 and Nissan like to use EGT sensor to monitor and detect system failure...HEY BOTTOM LINE !!!...NO CODES NO DEAL!!!!
Mar 29, 2007 at 11:19 PM
TAHOE24FAN
Ok we had a friend with a scanner scan it so we will have to have him rescan and get them or I will ask if he remembers. We have had the "Hoe" for almost a year and this is the first issue we have had with it so we are like newbies with this code scan thing. Thanks!
Mar 30, 2007 at 4:52 AM
KIN CHAN
  • 453 POSTS
advance and enchance data scan is whats mechanic today do in driveability performance diagnostic all day long..it is not some numbers jumps out and grab u to indicate the problems ..its years of experience and training to recognize a failure pattern to conclude to a problems...
all i'm asking u to get is the codes don't worry about the scan data ....leave that to a mechanic...await for ur results
Mar 30, 2007 at 6:56 AM
TAHOE24FAN
Ok thanks KC for being so patient! My husband works with the guy who scanned it and he is at work right now so I will get the codes when he comes home tonight. Thanks again!
Mar 30, 2007 at 7:34 AM
Suggested Repair
Visually inspect the fuel pressure regulator for a fine leak, a known issue on 5.3 engines. Also obtain the exact numeric OBD-II codes so the idle miss can be diagnosed properly.
Conversation Summary
The owner of a 2003 Chevy Tahoe 5.3 reported a check engine light after a long trip, described as fuel efficiency codes on banks 1 and 2, plus a miss at idle that clears when accelerating. Cleaning the mass airflow sensor did not help. A responder insisted on the exact numeric codes, and an expert said these engines can have a fine fuel pressure regulator leak that should be checked visually.
