1999 Chevy Tahoe Rich Running Injectors Fix
THOMSON
1999 chevy tahoe, 4wd, 350 5.7 112000 miles
truck was running bad, and really rich.
i was told that it waS MY INJECTERS.
i pulled the cover to expose the injecters.
the 4 injecters toward the back of truck
look like they are burned. not the injecter itself
but the tube looking wire part..
does that mean those injecters are bad,
if saw what could have caused that
thank you
Mar 6, 2007 at 5:12 PM
CHEVY22
  • 1,375 POSTS
your truck has whats called a poppet system , there is a fuel meter body at the rear with a regulator and the(spider) has one tube to each cyl , there are some people that sell just the tubes but i have never seen one up close , i would go to the dealer and get one
Mar 6, 2007 at 10:59 PM
Suggested Repair
Replace the poppet-style spider injector assembly from the dealer. The system uses a rear fuel meter body and regulator with one tube to each cylinder; individual tubes are not a proven substitute.
Conversation Summary
The owner of a 1999 Chevy Tahoe 5.7 said the truck ran poorly and very rich. After being told the injectors were bad, they found the tube-like parts on the four rear injectors looked burned and asked whether the injectors were bad and what caused it. The expert explained that it uses a poppet spider system with a rear fuel meter body, regulator, and one tube per cylinder, and recommended getting a replacement from the dealer.
