1997 Chevy Truck fuel pump
1997 CHEVROLET TRUCK
105,000 MILES • V8 • 2WD • MANUAL
JODAMARSH
Any tips on changing the fuel pump on a 1997 chevy p/u. Any problems I may run into?
Mar 9, 2008 at 4:41 PM
BLACKOP555
  • 10,386 POSTS
my biggest tip is to find replacement tank straps and cut the olds ones off that saves alot of time there.
its heavy so be sure to support it.
when you have it off scrub the inside of the tank out and flush it clean before puting in new pump and reinstalling the tank.
Mar 14, 2008 at 5:23 PM
CHISPAS
  • 20 POSTS
I had a similar problem years ago in my 90 Chevy Truck, being the cheap person and trying to avoid taking the gas tank down this is what I did.
I cut an access panel on the bed of the truck about 14x14 in. 7" each way from center of the pump , drill a 1" hole at each corner and cut between holes with a hack saw , you can use a saw-sawall use a short blade you have about 6" clearance from the tank to the bed ,that will give you plenty room to take the pump out .
Replace the panel by screwing a 1" flat metal strap all around 1/2 inch into the panel so when you put it back it will drop nicely in place , put 4 screws in each corner to fasten to the bed.
I have a bed liner so I don't worry about water leaking if you are just add some rubber around the panel before you put it back.
This will make it much easy to reach the pump next time if need it.
It worked for me and a couple friends like a charm..
Mar 14, 2008 at 9:45 PM
