1997 Chevy Blazer Exhaust Rattle
PAPAD1
1997 Chevy Blazer S-10 194,000 miles. After a recent service visit the following things have occured.
When started and idling there is a rattling sound in the exhaust.
(I assume it's the Catalytic Converter falling apart as I have a few miles on it.) Is this correct?
Also when I start my beater it is making weird sounds in the starter and sometimes it feels like it's drawing down on the electrical system.
(I assume it's just a matter of replacing the starter and possibly the solenoid) Is this correct?
Dec 30, 2006 at 10:02 AM
SERVICE WRITER
  • 9,123 POSTS
Not sure on the starter,
but the exhaust may have been crushed by a lift. Or it may have a heat sheild the is loose. IF you can rap on the exhaust with a rubber mallet, you'll be able to narrow down th source. May be as simple as getting a very large hose clamp and resecuring it.
Dec 30, 2006 at 2:57 PM
Suggested Repair
Inspect the exhaust for crush damage from a lift or a loose heat shield. Tap along the exhaust with a rubber mallet to locate the rattle; a large hose clamp may resecur a loose shield. The starter noise was not diagnosed.
Conversation Summary
The owner of a 1997 Chevy Blazer reported an exhaust rattle at idle after a service visit and starter noises that sometimes seemed to draw down the electrical system. The expert was unsure about the starter and suggested the exhaust may have been crushed by a lift or have a loose heat shield. Tapping with a rubber mallet can locate the source, and a large hose clamp may resecur it.
