2006 Chevy Truck PLUGGED CATS.
DODGE270
Engine Mechanical problem
2006 Chevy Truck 6 cyl Two Wheel Drive Automatic
changed dist. gear on a 2006 chevy pu due to teeth were worn off.after replacement now receiving codes that the cats. are plugged upped. there was no check engine light before the gear change
Jun 17, 2008 at 2:58 PM
  • 31,937 POSTS
Hi there,
I would start with just clearing the codes and driving the car. If the code re sets then we can look into it a bit closer.
Mark (mhpautos)
Jun 17, 2008 at 3:02 PM
DODGE270
i have re set the system 4 times using the solus pro scanner
Jun 17, 2008 at 3:09 PM
  • 31,937 POSTS
Hi there,
What is the code ID Number?
Mark (mhpautos)
Jun 17, 2008 at 3:16 PM
