Fires right up on starting fluid, so its a fuel problem, right? Have spark, checked with timing light. Noticed tonight, when I turn on the ignition, the fuel pressure gauge is not going up everytime, but if you turn the key a little further toward the start position the gauge jumps right up to 62#, when you start cranking the engine it almost starts then the guage drops to 40#, then it just turns over with out starting. I am really thinking the ignition switch may be my problem ! Any advise greatly appreciated.
This site has helped me alot !
SPONSORED LINKS
Thursday, May 28th, 2009 AT 8:48 PM
