1993 Chevy Truck won't start
JPTCARS09
  • 1993 CHEVROLET TRUCK
Electrical problem
1993 Chevy Truck V8 Two Wheel Drive Automatic
how do I do to find out why I don't have fire
Saturday, March 13th, 2010 AT 1:17 PM
Pick your symptom:
**Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
**No crank at all/nothing/nada:
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Sunday, March 14th, 2010 AT 5:16 AM
