1993 Chevy Truck won't start
CATSTOLUV
  • 1993 CHEVROLET TRUCK
  • V8
  • 4WD
  • 90,000 MILES
Replaced the fuel pump relay and still not getting power to it.
Monday, October 27th, 2008 AT 12:10 PM
MASTERTECHTIM
  • 4,750 POSTS
Do you have power at the fuel pump relay? Do you get power at the gray wire at the fuel pump relay? If you have power at the gray wire at the relay when cranking then check the wire for a break going to the tank.
Monday, October 27th, 2008 AT 6:21 PM
CATSTOLUV
We do not get power to the orange wire on the relay. We put power to the orange wire and it starts. We need to know why it will not get power the right way.
Tuesday, October 28th, 2008 AT 1:43 PM
MASTERTECHTIM
  • 4,750 POSTS
Fuel pump fuse blown? I believe its located in a plastic little fuse case near the relay
Tuesday, October 28th, 2008 AT 2:47 PM
CATSTOLUV
This model has no fuse that we can find.
Tuesday, October 28th, 2008 AT 5:44 PM
CATSTOLUV
I am sorry I was wrong. They did check that fuse and it is good.
Tuesday, October 28th, 2008 AT 5:47 PM
MASTERTECHTIM
  • 4,750 POSTS
Do you have power at the fuse? If yes then the wire is broken from the fuse to the relay. If no power then check the fusible links at the starter motor of at the firewall. The fusible links are the soft orange wires that connect to the red power wires. Lightly pull on the red wire and if the fusible link is blown then the orange rubbery wire will beak in two.
Tuesday, October 28th, 2008 AT 6:06 PM
