1993 Chevy Truck will not start
THOMAS HURST
  • 1993 CHEVROLET TRUCK
  • V8
  • 4WD
  • 135,000 MILES
Wae running fine friday night then would not start saturday morning.A new fuel pump was installed three months ago. I even put a little gas in carb turns over good but acts like it is getting no fire to plugs
Sunday, December 6th, 2009 AT 8:55 AM
JDL
  • 16,098 POSTS
Welcome to the forum, how long since tune-up? Visually check for spark at the plugs with engine cranking. You can pull plug wire, stick known good plug in the boot, ground metal part of plug to metal part of engine, have helper crank the engine while you watch for spark at tip of plug. Also, check fuel pressure and trouble codes.
Sunday, December 6th, 2009 AT 10:31 AM
