This is a fuel loss problem, not spark loss.
Evidenced by the statement:
" can start it if I spray starting fluid in the throttle body though so basically its not sending fuel when it is warm"
Check the fuel pressure when the problem is happening as stated by CHEVY II.
Unless you want to add another problem or two to the mix.
Friday, March 2nd, 2007 AT 9:08 PM
