1993 Chevy Truck
WILLIAMS1228
  • 1993 CHEVROLET TRUCK
1993 Chevy Truck 6 cyl Two Wheel Drive
I was going down the road and it died I lost power steering, brakes, and it would crank but it wouldnt start and I thought it was the starter but the brakes would'nt go out so please help I have to jog to work everyday thanks.
Saturday, August 8th, 2009 AT 7:32 PM
Check what's missing fuel or spark
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Saturday, August 8th, 2009 AT 8:10 PM
