welcome to the forum, did you check the coil primary circuits? Pink wire is voltage, goes hot when you turn on the key. Use a testlite, is there voltage?
Engine cranking, the white wire should have a pulse on it. How long since a tune-up? Any codes?
Jan 14, 2010 at 7:46 AM
