1979 Chevy Truck Engine dies
ROD13
  • 1979 CHEVROLET TRUCK
Engine Performance problem
1979 Chevy Truck V8 Two Wheel Drive Automatic unkown miles
i have a 79 scottsdale, with a 350 5.7 gas, 4bl carb. I just put the new carb on it, and set it right, or so I think, it also has a new fuel pump, spark plugs, battery, and wires. It seems to start fine, and run fine when I drive. But when I go at low speeds or sometimes when I idle, and slow down. It wants to just sink and die down, sometimes itll save itself, sometimes it wont.
Thursday, June 3rd, 2010 AT 6:06 PM
Check and test the EGR and PCV valves
Friday, June 4th, 2010 AT 9:19 AM
ROD13
I checked and replaced them both, that didnt do it. Any other suggestions?
Saturday, June 5th, 2010 AT 6:15 PM
If it has a heat riser check if its opening, also check if the choke plate is fully opening when engine at normal temp. Also try adjusting the idle speed
Saturday, June 5th, 2010 AT 9:02 PM
ROD13
There is no heat riser, and the choke plate is operating fine.
Monday, June 7th, 2010 AT 8:21 PM
Check the fuel pressure if its within specs and also for a kinked fuel line, clogged fuel filter and fuel lines back to the tank-also test the PCV valve
Double check the adjustment of the A/F mixture and Curb idle speed
Monday, June 7th, 2010 AT 9:38 PM
ROD13
Fuel lines are all good, pcv valve is fine. Adjustments are good too.
Friday, June 11th, 2010 AT 5:50 PM
