HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Trailblazer
Engine Cooling
Water Pump
2004 Chevy Trailblazer
MUNCHKIN2531
MEMBER
2004 CHEVROLET TRAILBLAZER
6 CYL
2WD
AUTOMATIC
80,000 MILES
The fan water pump assembly seems to be very loose, can it just be tightened or is it a bigger problem
Thursday, November 26th, 2009 AT 12:40 PM
MECHANIC
Can you tell me where in those parts it is loose? Is the entire pulley moving with the water pump? Is it making noise? Do you have any coolant leaks?
Tuesday, December 1st, 2009 AT 7:53 AM
MUNCHKIN2531
MEMBER
The car is not leaking any coolant, the pulley assembly and fan with the shahaft are all loose, took it to a friend he says its the water pump.
Tuesday, December 1st, 2009 AT 11:13 AM
Please
login
or
register
to post a reply.
Related Water Pump Content
2004 Chevy Trailblazer 2004 Antifreeze Leak From Ac...
Engine Cooling Problem 2004 Chevy Trailblazer 6 Cyl Four Wheel Drive 110000 Miles I Have Antifreeze Leaking Out Of A Tube On The Front...
Asked by
chrisfarris
2004
GUIDE
Water Pump Symptoms
The water pump is designed with a weep hole to allow coolant to leak from its housing before it can reach the shaft bearing which will cause the shaft to lock up and stop...
Coolant Leaking From Rear Heater Coil Need To Bypass...
Coolant Leaking From Rear Heater Coil Need To Bypass Or Repair Need Cheap Solution Untill Able To Repair
Asked by
Anonymous
1 ANSWER
2004
I Am Trying To Figure Out Where The Engine Coolant...
The Engine Is A V6, And The Upper Radiator Hose Is Slightly To The Passenger Side, And Hubby Says The Thermostat Is There, I Can't...
Asked by
nhilton1
6 IMAGES
2005
Where Is The Thermostat Located At On A Chevy...
Where Is The Thermostat Located At On A 2005 Chevy Trailblazer. Mine Is Staying Open And Needs Replaced.
Asked by
sjfultz
7 IMAGES
2005
1997 Blazer 4wd Antifreeze Leak
I Have A 97 Blazer That Has An Antifreeze Leak Which Is Not Coming From The Radiator Or Hoses. It Originally Appeared Like It Was Coming...
Asked by
mfcarose
1997
VIEW MORE
Water Pump Replacement
How to Replace Water Pump Ford F-150
Water Pump
