I have a 97 Blazer that has an antifreeze leak which is not coming from the radiator or hoses. It originally appeared like it was coming from behind the waterpump, so I replaced it and it still leaks (not from waterpump). It leaks even when the vehicle is not running. When I pour water/antifreeze in the radiator, it starts leaking below the motor, but I can't tell for sure were it is coming from since everything is so tight in the engine compartment. I checked the oil for water/antifreeze and do not see any, so I don't think it's the head gasket. Any suggestions would be appreciated. The Blazer has 140,000 miles and has been running great, it's just that this leak started.
thx.
SPONSORED LINKS
Friday, December 15th, 2006 AT 3:50 AM
