Tahoe Fan Control
2765GDV
  • CHEVROLET TAHOE
I have a 2000 Tahoe with 90,000 miles. Just recently the fan control which has 5 positions, only works on the highest setting. Settings 1 through 4 do not activate the fan. Can this be related to a fuse or is their some seperate module that controls the lower speeds? This vehicle also has a fan control for the rear air and it is unaffected and works fine.
Wednesday, August 1st, 2007 AT 10:46 AM
CLY
  • 308 POSTS
I would say that you have a bad blower motor resister. It is located right there by the fan. If you have a test light then you can check the wires for power as you operate the switch.
Cly
Wednesday, August 1st, 2007 AT 5:25 PM
