2001 Chevy Tahoe Low beam headlights
ROBWINTERMUTE
  • 2001 CHEVROLET TAHOE
  • V8
  • 4WD
  • 200,000 MILES
My Low beam head lights stoped working and only the high beams now work I have replaced the bulbs in both lights and they still do not work. I also checked the wiring from what I can see and nothing looks damaged. What could be causing just the two low beam headlights not to work if all other head lights and turnsignals are functioning properly
Thursday, January 14th, 2010 AT 8:44 AM
RACEFAN966
  • 5,029 POSTS
After looking at the wiring diagram for you truck, it looks like I would replace the headlight dimmer switch. The headlight relay and fuse send power to both the low and high beams, but the dimmer seperates which bulbs get the power when you select high or low beam.
Thursday, January 14th, 2010 AT 10:58 AM
