1999 Chevy Tahoe Won't Start
CHAS1966
  • 1999 CHEVROLET TAHOE
  • V8
  • 4WD
  • 125,000 MILES
Died on the highway. Towed back home. Days later, started fine. Replaced fuel filter and drove around town. Would not start the next morning. Changed fuel filter again, but no improvement. Changed the ignition coil. No improvement Will sputter with carb cleaner sprayed in the throttle body.
Checked all over for loose wiring, but found none.
Has 0 engine codes.
Any ideas? Could the injector be clogged?
Thursday, November 5th, 2009 AT 6:09 PM
Check the fuel pressure to rule out a weak fuel pump, also test the fuel pump relay and fuel pump and oil pressure sending unit
Thursday, November 5th, 2009 AT 6:14 PM
CHAS1966
Low fuel pressure. Replace the fuel pump and all was well. Don't understand why it only lasted 1 year.
Monday, November 9th, 2009 AT 6:44 PM
Never under estimate bcuz its new there's such thing as manufacturers defects-Glad you got it going-Good luck
Monday, November 9th, 2009 AT 6:46 PM
