About 3 weeks ago I began to experience trouble getting my tahoe to start. It would turn over and finally it would start. The problem has progressively worsened, and finally yesterday while driving down the freeway the motor cut off and would not start again. I changed the fuel filter, it was filthy, black and clogged and the motor still does not start.W hat are some other common problems in the fuel system I should look for, and in what order do I proceed?
Also when I removed the cover from the throttle body and poured fuel in, the truck started but then immediately died.
SPONSORED LINKS
Thursday, September 18th, 2008 AT 6:07 AM
