Your spark should be bright blue and well defined, when you said the plugs were fuel soaked I didnt think much of it, but now im thinking you may be getting too much fuel.
Bleed the fuel system of all fuel and disable the fuel pump from turning on. Then crank it for a bit till there is absolutely no fuel in the lines. Then I would like you to try and crank it while having a friend spray starting fluid into the throttle body, if it fires right up you are getting too much fuel.
But if your spark isnt bright blue and well defined nothing is going to happen.
Its just a thought.
Maybe try pumping the accelerator when cranking before trying all of this.
Saturday, December 29th, 2007 AT 12:20 PM
