1999 Chevy Tahoe Crank, no start.
DOLEARY6666
  • 1999 CHEVROLET TAHOE
  • V8
  • 198,600 MILES
When the weather is wet (snow or rain) my truck will crank, but not start. I have fuel, fuel pressure, and spark. I did have check engine messages that I have two bad O2 sensors. Could this be the problem? If so, any direction on how to put them in?
It smells like it is flooded, too much fuel.
Thanks,
Dan
Saturday, February 27th, 2010 AT 9:07 AM
JDL
  • 16,098 POSTS
Hi, thanks for the donation. If the 02 sensors are the problem, the code should point, which 02. As far as removing the sensor, it is straight forward. Take the electrical connector loose, unscrew the old sensor, screw the new one in, reconnect connector. I'd also want to use a fuel pressure gage on the fuel system, check for proper pressure and that it doesn't drop like a rock, when everything is turned off.
Saturday, February 27th, 2010 AT 2:41 PM
DOLEARY6666
  • 6 POSTS
I don't know where the O2 sensor is located? Any direction?
Thanks,
Dan
Saturday, February 27th, 2010 AT 3:46 PM
JDL
  • 16,098 POSTS
Oops, sorry about that.
http://www.2carpros.com/forum/automotive_pictures/170934_oxygen_sensor_1.jpg
Picture of up-stream oxygen sensor.
http://www.2carpros.com/forum/automotive_pictures/170934_upstream_oxygen_sensor_1.jpg
Sunday, February 28th, 2010 AT 8:47 AM
DOLEARY6666
  • 6 POSTS
Thank you, that helps out a lot.
Can the O2 sensor cause my problem though? I have never heard of an O2 sensor causing a crank no start problem.
I don't want to replace them and that not be the main problem, thay cost 85.00 a pieces times 4.
Thanks again,
Dan
Great web site, I fill refer you to friends!
Sunday, February 28th, 2010 AT 11:39 AM
JDL
  • 16,098 POSTS
I don't think they should stop it from starting. Some of the national brand autostores used to loan out a fuel pressure gage, if you don't have one.
Sunday, February 28th, 2010 AT 11:59 AM
