1999 Chevy Tahoe V8 Four Wheel Drive Automatic 144K miles
I have 99 Tahoe, one day out of the blue it wouldn't start. I read all the posts so I did what everyone was doing so I checked for spark, got it. Then I checked and replaced the fuel filter, no luck. Then I replaced my battery, no luck. Checked fuel pressure, it read 66 so all is good with pressure. I checked the injectors, well I checked to see if they were getting power using a noid tester and they are getting power. I sprayed Sprayed starter fluid, no luck. No check engine light ever came on. If I'm getting spark could either one of the camshaft or crankshaft sensor's be out? I'm at a loss. I did notice that when I pulled a plug it didn't seem wet from gas in the cylinder. Anyways need help.
SPONSORED LINKS
Monday, December 28th, 2009 AT 11:29 PM
