Pull plug wire hold next to block crank spark? If yes spray carb cleaner into intake crank run?
SPONSORED LINKS
Thursday, December 3rd, 2009 AT 10:42 AM
KBEAGLE1
MEMBER
1 POST
It went from running great to turning it off to run in store. Came out and will turn over but not start. Strange. Could something go out that fast without any prior problems?
Thursday, December 3rd, 2009 AT 10:49 AM
WILLIAM LABRECQUE
MEMBER
Yes. I had the same problem once. Switch your AC & your fuel pump relays and see if it remedies the problem. If so buy a new relay.
