The fuel pump cycles and appears operational (it was replaced about 9 months ago) and there seems to be sufficient pressure at the check valve. I tried to prime the engine with both gas and a starting fluid, but it still would not start.
I have ample spark to the plugs which should eliminate a crankcase sensor issue. I have checked all the fuses and relays that I could think of but at this point I am completely stumped.
Can you think of anything that I might be able to check next?
SPONSORED LINKS
Saturday, June 5th, 2010 AT 4:23 PM
