1999 Chevy Suburban will not start
SOLISKELLY
  • 1999 CHEVROLET SUBURBAN
1999 Chevy Suburban V8 Automatic
I have a 99 burban it will not start. Changed the starter. When you try to start the motor turns over then you hear a loud clanking noise. You can also see a sprak from the flywheel. I need help
Monday, April 14th, 2008 AT 10:20 AM
RHALL77
  • 3,361 POSTS
Sounds like maybe your fly wheel is broken. Is that why you replace the starter?
Friday, October 4th, 2019 AT 3:43 PM
SOLISKELLY
No one of the bolts was loose. My husband said the flywheel didnot look damaged, but he didnt take it off
RHALL77
  • 3,361 POSTS
Does he have it fixed then
SOLISKELLY
I will tell him about the flywheel, and have him remove it. Then if that is not the problem I will get back with you. Thanks for your help
BSNAR
A lot of these chev starters have to be aligned properly with shims so you do mnot have the problem you describe --I highly doubt any bproblems with the flywheel-- check with youyr parts man for proper shims
