No Power to car / Won't start?
TROYER
  • 1999 CHEVROLET SUBURBAN
  • V8
  • 4WD
  • 15,000 MILES
Car won't start nothing electrical works when key is on or off. I tried jumping still no power comes through system. Battery is good, tried head lights and other items none work. Won't turn over or show signs of life. Also checked battery connections they are good and battery has power it's like there is something from keeping power to the entire car.
Sunday, July 19th, 2009 AT 8:17 PM
BUDDYCRAIGG
  • 2,262 POSTS
Here are some potential causes to consider:
Main Fuse or Fusible Link:
Faulty Ignition Switch:
Battery Cable or Ground Connection:
Faulty Battery:
Security System Malfunction:
Friday, October 4th, 2019 AT 3:42 PM
TROYER
Yes I checked two cables off the positive battery terminal one goes to a black box mounted behind radiator area. The other down into engine or starter
Friday, October 4th, 2019 AT 3:43 PM
BUDDYCRAIGG
  • 2,262 POSTS
Take those cables off, and remove the bolt.
There is a thick lead washer, about 3/8 think.
A really hard greenish/blue deposit builds up on the washer and also on the cables that will not let electricity flow.
TROYER
That seems to have worked that middle piece I didnt check the first time around. Got it running and it took a charge so thanks!
BUDDYCRAIGG
  • 2,262 POSTS
Glad to have helped,
come back anytime.
