My suburban has been running fine till last week. One day I went to start it and it cranked over good but would not fire.I pulled a spark plug and it looked dry. I have spark, and I can hear the fuel pump run for a second or two then shut off. If I spray some starter fluid into the intake ductwork, it will start and run fine. Since it will run after its started on starter fluid I assume the fuel pump is ok. (It was replaced last fall, plus I can hear it pump up pressure and stop when the key is turned on) It seems like something is not allowing the injectors to deliver fuel while the starter is running, but, after it starts on fluid, they are fine. Also, after it starts, I can shutt off and restart like normal.
SPONSORED LINKS
Saturday, May 16th, 2009 AT 8:30 AM
